| Internal and External Spur Gears | ![]() ![]() |
The most common type of gear is the spur gear. These gears have straight teeth and must be mounted on parallel shafts for their teeth to mesh with those of other gears. The disadvantage of spur gears is that they make a lot of noise when they are used at high speeds, and their design puts lots of stress on the gear teeth. For this reason spur gears are known as slow speed gears. The noise of spur gears can be reduced by precision gear grinding. |
