| Straight Cut Bevel Gears |
Straight cut bevel gears are gears where the axes of the two shafts intersect and with the apex of the pitch cones lying at the same point. The size of a bevel gear tooth diminishes as the cone apex is approached. The tooth bearing faces of bevel gears are conically shaped. Bevel gears are most often mounted on shafts that are 90 degrees to each other but can be designed to work at other angles except 0 and 180 degrees. Bevel gears with equal numbers of teeth and shaft axes at 90 degrees are called miter gears. For high performance straight bevel teeth can be cut with coniflex (a Gleason term for crowning). This allows for any miss-alignment inherent in the machining of the gearbox or to reduce the effect on the bevel gear teeth of the gear mounts deflecting under load. |
